NEW KingSound Electrostatic Headphone 1 - Save up to $400 w/ Headphone AMP Package DEAL!!
Aug 14, 2013 at 9:00 AM Post #16 of 27
Thanks for the feedback. The same feedback was given by all who listened at the California Audio Show this past wknd. One of the Best Bang for the buck set ups in Headphone Audio. The Tube amp is even better. At CES when i heard the Prototypes I was favoring the SS setup. But the final production version of the Tube Amp M-20 is amazing. And the tubes are common so tube rolling will be next on my list:)
Drew, a bit more feedback. I am listening to one of my favorite recordings of all time "the Traveling Wilburys - Volume 1 and 3. I listened to the music first with the LCD-3, then the HE-500 and finally switched to the Kingsound set up. Now, I am officially committing blasphemy when I say (or write this) but the Kingsound blew the LCD-3 and the HE-500 right out of the water. Clarity, detail, bass depth and extension - no contest. The first two sounded more congested. I need to listen to more recordings before I make a definitive generalization but I thought I would let you know. I am using the same DAC for all three HPs so the amp for the first two set ups (LCD 3 and HE 500) may be a contributor. Not sure yet but loving the Kingsounds.
Apr 29, 2014 at 10:49 AM Post #17 of 27
Upgrade to the KingSound KS-H2 Electrostatic Headphones!
$650.00
Free U.S. Shipping
$650.00 KingSound KS-H2 Electrostatic Headphones
KingSound has introduced the KS-H2 Electrostatic Headphones with improved headband and cups from the KS-H1. All other attributes of the KS-H2 remain the same including the drivers and sound quality.
For a total improvement of the KS-H1 try the NEW KS-H3 Electrostatic Headphones with new improved headband, new improved drivers, and a new sound.
The KS-H2 headphones are the second electrostatic headphones created by KingSound. Moon Audio has included a description of the technology behind Electrostatic headphones and loudspeakers below.
How do Electrostatic headphones and speakers work?
The electrostatic loudspeaker is very simple in concept, but difficult to construct successfully in practice. The operation relies on electrostatic attraction and repulsion, in much the same way as a piece of thin paper attracted to a rubber balloon that is charged by rubbing it against fabric.
The electrically charged ultra-thin conductive film diaphragm is tensioned and placed close between two metal grids. When a high voltage audio signal is applied to the metal grids, the diaphragm moves in response to the signal, moving towards the grid which at that instant is oppositely charged, and away from the grid which has the same charge as the diaphragm. The diaphragm responds in an essentially linear manner, producing sound waves which are a very accurate reproduction of the original sound.
Why is it better?
Imagine a normal speaker as a point source, from which the sound waves produced diffract at a great angle. This causes rapid decrease in volume and quality over a short distance.
Then imagine a flat electrostatic panel producing sound from the same input signal. This time the sound waves are produced over a large, flat area, therefore they have very little diffraction and the volume decreases much less over the same distance.
Specifications
Frequency Response10Hz - 46kHz
Electrostatic Capacity140pF
Impedence113kΩ (at 10kHz)
Sensitivity109 dB (at 100vrms)
Maximum Output Sound Level 116dB
Standard Bias Voltage550Vdc
Weight0.42kg
Thank You.​
Drew Baird
Moon Audio​
https://www.facebook.com/MoonAudio/ https://twitter.com/MoonAudio https://instagram.com/moonaudio https://www.moon-audio.com/ https://www.youtube.com/@moon-audio sales@moon-audio.com
Apr 29, 2014 at 11:03 AM Post #18 of 27
Upgrade your KS-H1 Headphones to the
NEW KingSound KS-H3 Electrostatic Headphones!
$750.00
Free 2nd Day U.S. Shipping- Limited Time!
KingSound KS-H3 Electrostatic Headphones with KingSound M-20 AMP
Free 2nd Day U.S. Shipping - Limited Time!
$750.00 KingSound KS-H3 Electrostatic Headphones
The new KS-H3 headphones from KingSound have a new improved headband, new improved drivers, and a new sound. Once again, King Sound has improved this very affordable electrostatic headphone and introduced the KS H3 at a very affordable pricepoint of only $750.
Moon Audio is excited to be able to introduce the King Sound KS-H3 headphones. Moon Audio has included a description of the technology behind Electrostatic headphones and loudspeakers below.
The electrostatic loudspeaker is very simple in concept, but difficult to construct successfully in practice. lts operation relies on electrostatic attraction and repulsion, in much the same way as a piece of thin paper attracted to a rubber balloon that is charged by rubbing it against fabric.
Why is it better?
Specifications
Frequency Response6Hz - 46KHz
Sensitivity 109 dB (at 100vrms)
Weight 0.46kg
Thank You.​
Drew Baird
Moon Audio
May 18, 2014 at 5:28 PM Post #19 of 27
Is the KS-H3 headphone compatible with the Stax SRM 2525 driver amp? (i.e does the plug fit?)
May 19, 2014 at 1:14 PM Post #21 of 27
Excellent, thank you.......time to investigate other electrostats....hmmmm
Jun 15, 2014 at 2:27 PM Post #23 of 27
You can order either the KS-H2 or KS-H3 with amps here: http://www.moon-audio.com/headphones.html?limit=30&manufacturer=78
Thank You.
Drew Baird, P.E.
Moon Audio
140 Iowa Lane
Suite 204
Cary, NC 27511
919-649-5018
drew@moon-audio.com
Follow us Today!
Jun 23, 2014 at 5:03 PM Post #24 of 27
Jun 23, 2014 at 5:19 PM Post #25 of 27
What's sketchy about it? They are warrantied for 1 yr from purchase date. Return policy is here: http://www.moon-audio.com/customer-service
Here are some reviews:
http://www.cnet.com/news/astonishing-headphones-with-clarity-like-youve-never-heard-before/
http://www.stereotimes.com/post/kingsound-ksh3-headphones--m20-amp-energizer
http://parttimeaudiophile.com/2014/04/27/axpona-2014-king-sound-headphones/
http://www.hifiplus.com/articles/ces-2014-headphone-earphones-and-related-electronics-part-2/?page=3
http://headfonics.com/2013/12/the-kingsound-electrostatic-headphone-system/
http://www.positive-feedback.com/Issue70/kingsounds.htm
Aug 10, 2015 at 10:52 PM Post #27 of 27
I know this is an old post and I'm not an expert in this hobby I can only share what I experienced. I owned a Stax SRM-006t and a pair of 507's. I purchased the H-03 and the M-10 and sold my Stax setup. First I didn't like them but after they broke in the KingSound floored me and sound better than the Stax to my ears. I too would like to try another amp and am considering the SRM-727. The funny thing is the M-10 sound Great but my mind just won't accept that it could cost so little and sound this good.:D
