doraymon
You can message Tim Connor of Holo Audio USA aka @bimmer100How does one go about purchasing a holo audio cyan...
He'll take care of you.
Not really. If I were you, I would pick microrendu/ ultra-rendu without a second thought. It's not about Roon, it's about HQplayer NAA (network audio adapter). Have a look at the HQplayer site or join the CA community, lots of sensible nerds discussing such there.
In short, by having NAA, you will literally galvanically isolate your HQplayer DSP PC from your DAC since ethernet transmission is inherently galvanic isolated. So you will be less worried about the RFI/EMI your PC generates during intensive HQplayer processing transmitting to your DAC/interface via usb cable. You can literally place your PC and microrendu at two difference places. Disadvantage of it is: your cannot stream your youtube or movie through your system, but these things have crappy SQ, so I never bother streaming them from PC to my HIFI system.
NAA as a second setter, only do the bit-perfect transmission without doing heavy processing. So it can be a compact, small, low-power consumption, software optimized NUC (I regard microrendu as a linux-based NUC as well), you can have better signal integrity USB output and less noise problem. It's also easy for you to upgrade lots of accessories such as LPSU for your NUC (since they are low power consumption, find a good LPS-1 is much cheaper and easier than big linear power supply in your PC).
You can go for ultra-capacitor-based LPS like LPS-1 from Uptone or mini-dc-4ever from VR and your microrendu powered by these things are basically off the gird. You can also put a optical ethernet switch in between, and install a NIC pice card on your PC, so you transmit your HQplayer DSD512 data through your PC via optical Ethernet cable which is a step further of isolation compared to normal copper Ethernet cable. Thinking about these up-gradable and flexible options.
Only one thing you need to be careful is some DAC supports DSD512 (44.1k or 48k) only on windows OS like my T+A DAC and your DAC supports DSD512 at 48K base only on linux. I prefer a linux-based NUC since it save me the trouble to optimize OS and product like microrendu has optimised its USB output. But unfortunately, i cannot use them since my DAC's firmware does not support it.
You can also upsample DSD64 file to DSD512 one without PCM conversion, this is also one of the unique selling points of HQplayer, which also yield wonderful result. Just untick the DirectSDM in the DSF/DSDIFF settings.
. On the bright side, USB transmission won't be an issue due to the ISO REGEN that's under my disposal. It offers true galvanic isolation and cleans up the USB signal. I also have a Singxer SU-1 converting that USB signal to the superior balanced I²S before making it's way into the DAC. All ultra low jitter and noise methods.
I see why you would recommend the two items from Sonore as it's an easy solution in solving the USB output noise/signal issue as well as easily being powered by something like the well regulated LPS-1 with the addition of being free from AC Leakage Currents.
Or should I get the cheaper mRendu and keep the iSO Regen. Or do you think the mRendu alone is good enough?
I can't just wipe out Windows OS for Linux since the majority of productivity and all it's needed programs are Windows based (video editing programs, etc).
Why didn't you switch over to the Spring instead?
IIRC, John Swenson mentioned that although ISO REGEN has a good galvanic isolation using high-speed isolation chip, it cannot isolate the noise completely. That's why the microrendu/ultra-rendu has a different approach using more solid way, since ethernet transmission is galvanically isolated by standard. Otherwise, these companies, hospitals, schools will have trouble with many Ethernet cables in their buildings.
I think one of the merit of microrendu is its compact size, so you can put it right back of your dac and being stealth while ultrarendu is bigger and claimed to have better main board design, clock and stuff like that. But microrendu also has its uprgrade option, and the total price will be the same as ultrarendu, who is better? I have no idea.
I would pick ultrarendu and keep the iso regen as well. So the logic is like this: Ultrarendu does the galvanic isolation from your HQplayer PC the first time via ethernet, and then ISO-regen does the galvanic isolation from the ultrarendu the second time via its high-speed chip. (since ultrarendu is also a NUC, it has its own noise interference, but much smaller than your HQplayer PC again)
Regarding the performance, in my case, i put a windows based NAA, a NUC (Logic CL100) between my audio system and my HQplayer PC, and its USB has not been optimized like microrendu, I can already feel the obvious improvement. The sound is much cleaner.
I won't encourage you to use LINUX system for your HQplayer PC as well if you have so much other fun on windows OS. In my case, I will also stick to the windows OS. My i9 7980XE and Titan xp is on the way to me, for that combo, installing linux just for HQplayer is a waste I think. VR gaming, data processing, video editing, etc these things will equally make you life productive and happy.
However, linux based HQplayer is quite different from windows desktop one, it's a embedded one, having some more advanced function. I might consider build another Linux server for HQplayer PC to give Linux HQplayer a go in the future. But I doubt whether I can leave Roon's UI and Tidal (I'm using Roon+HQplayer +Tidal+ lots of DSD files in my local drivers), and do I need that many PCs at home?
I like my T+A DSD512's sound and T+A is working on linux firmware at the moment, so I'm going to wait instead of purchasing other DACs.
You make some very solid points. For that I plan to make my next purchase the Sonore ultraRendu (and LPS-1). For awhile I imagined the ISO REGEN to be doing more than what it actually did. I thought galvanic isolation was complete isolation so I did no bother with any other forms of NUC's and focused heavily on the 16-core computer for HQPlayer's xtreme filter.
So if Ethernet transmission offers complete isolation, does this mean I simply put the Sonore ultraRendu right after the computer and connect the two together using Ethernet CAT6 cable? You said there would be more isolation if I got an optical ethernet switch box as well as an optical Ethernet output PCI-E card for the computer? Does these two transfer data using light thus why there is better isolation? But I thought you said Ethernet was already isolation why need for light? Wouldn't light result in timing delays like with other optical connections as seen within DAC's or does it get reclocked again once the data reaches the NUC?
I think I will start small and grab the Sonore ultraRendu + LPS-1 first. Since you recommend keeping the ISO REGEN, is it okay if I use the iPower to power it? My other LPS-1 is already being used on the Singxer SU-1. I think it would be crazy expensive to have three LPS-1's for such minimal gains considering the SU-1 already consist of digital isolators within it. The Singxer SU-1 im using already draws LPS-1 power and so the iPower only powers the ISO REGEN as well as the USB input side of the Singxer SU-1.
Furthermore, with this addition I should be able to play DSD512 in 48KHz right? I'm pretty sure my 16 core computer can do it since it's running at 4.1GHz overclocked.
Do you recommend any good performing Ethernet cables but on the cheap side? I've been going through financial problems lately and can't afford to spend hundreds on an Ethernet cable. The optical method you suggested I may try in the future once I better understand it and have learned it's advantages alongside its translation on obtaining higher sound quality.
Great thread!
I own a T+A DAC8 DSD and I also have ISO REGEN. I currently use hqplayer with PCM upsampling to 352k. The sound is great.
I am planning to buy a PC for DSD512. From what I can see the AMD 1920x may be the best option. Can anyone confirm if it's good enough for top XTR modes? (both 44.1k and 48k)
@Energy ,
Always happy to help! I think it best to link back to the source material that started these revelations:
https://www.computeraudiophile.com/...ndu-ultrarendu/?do=findComment&comment=724269
The link above refers to the NetGear switches by name and model number and Cisco switches by name. I’m not sure if that’s all or some Cisco switches but the NetGear is easy to get and cheap so
I didn’t look any further. I snagged mine for $12 off of eBay (new) and they can be had all day long on Amazon for $20 (new).
I would like to clarify a point you made if I could. You mentioned above “regardless of optical or ethernet switch, either switches make noise and should have it’s negative grounded.” I wouldn’t go as far as to expand the scope to say all switches will benefit from this grounding. As stated in the following link “The property of shunting leakage from OTHER boxes only seems to work with these [NetGear] switches. Grounding the SMPS with switches other than these doesn't seem to do this.”
https://www.computeraudiophile.com/...ndu-ultrarendu/?do=findComment&comment=738368
As a result of that comment and the low cost of the NetGear switches I would limit the pool of switches that you plan on using to the previously mentioned NetGear switches.
An optical switches noise isolation is 100% from all other network components on the network EXCEPT for the noise from the switch itself. The ethernet grounding (with the NetGear switches) allows a significant amount of noise from the entire network and the switch to be blocked. I haven’t seen any measurements but it boils down to all “all of the last optical switches noise” vs “a very small percentage of the total network noise.” No idea who would win but it’s probably manufacturer and design specific.
If I had to do it over again I’d still go with the FS105. I am maybe $70-80 into this tweak including the switch and additional ethernet cable so it’s dirt cheap as far as mods go for a small but noticeable improvement. The biggest change I heard was a blacker background.
You can power the switch with a LPS but it probably won’t net you much. My switch is actually powered by an LPS not out of necessity but out of convenience. I was only using one of four 12V output from my LH Labs LPS4 so it made sense to use another output for the switch. The switch would block the low-impedence noise from whatever is powering it so that’s why I think it wouldn’t matter whether you use an LPS or SMPS.
On the subject of cables, it is my opinion that the Supra CAT8 cables helped a tiny, tiny bit with the sound compared to my generic CAT6A cables but it honestly could have been the placebo effect. I’ll keep them in there though because buying the three cables didn’t break the bank and I like the piece of mind.
(To those of you reading this who are anti-network cable’s make a difference, I did say that was my OPINION. Please no flame spray.)
Great thread!
I have i9 7980XE and Titan Xp intalled. Did a few experiments myself with T+A DAC8 DSD. I can confirm you a few things:
1. When doing upsampling using poly-sinc-xtr 44.1→44.1*512, Titan Xp is pulling 7980XE's leg, causing playback stutter. So in terms of GPU's cuda offload, adding any gaming graphic card won't help for the poly-sinc-xtr filter.
2. i9 7980XE alone can do 44.1 → 44.1*512 and even more extreme setting 48K*512 at poly-sinc
3. i9 7980XE alone can do 44.1 → 44.1*512 or 48K based file → 48*512 at poly-sinc-xtr but cannot do 44.1 → 48K*512, I tried to overclock the i9 7980XE and had a few chat with Jussi (desinger of the HQplayer). Turn out it to be 44.1 → 48K*512 at poly-sinc-xtr is not only hungry for CPU horsepower but also for cache/ram speed.
As for the sounding, it is always being personal preference. I prefer 44.1 → 48K*512 to 44.1 →44.1*512 at poly-sinc. Difference is not subtle.
Poly-sinc-xtr at DSD512 is just beautifully smooth, this is a very well-tuned filter, I especially use this filter for some vocal music while ussing poly-sinc for classical orchestral music.
Can't help you with the 1920X, i9 7980XE is quite faster than 1950X, so you can have a rough idea how the settings will go.
