New and Looking for the ones
Oct 15, 2013 at 6:39 PM Post #16 of 19
So, I've been looking around, and found basically what I'm looking for. I believe I'm going to be going with the HD439, closed circumaural detachable headphones, and a cable for beats by Dre that I found for $11 that has the three button remote integrated into it.
The other option I saw was a bluetooth remote that had all of the buttons on it and the headphone jack. I can use it by itself and plug the headphones into my iPhone. It's not ideal, but about the only option I came up with under $100 and has a good style and sound. I think the V-MODAs would be a good option, but between the looks and being over budget, it's not looking good for them.
Any other thoughts of good headphones with a detachable cable for $50 or so? Definitely want it to be a sleek look and good sound quality.
Hmm must of forgotten those  lol :)
I love the stylish look of my V-moda M-100 ( Same look) so it is what it is and looks sleeker then Sennheiser hd439 ( since they are priced at around 80 bucks? )
Oct 15, 2013 at 11:00 PM Post #17 of 19
Yeah, Amazon has them for $85 shipped. But I'm not sure if you can answer this question or if I should start a new thread, but reading information on the HD439, their cable locks into place, possibly by twisting a bit. I email Sennheiser and asked if their Momentum cable fit and they said they are NOT interchangeable. Even if the cable doesn't lock, should it be a snug enough fit? Does any 2 pin 1/4" cable fit into detachable, or does it depend on the manufacturer?
Oct 17, 2013 at 11:59 AM Post #18 of 19
I figured I'd update this thread since I found a good enough compromise. Instead of an interchangeable cable and the bluetooth remote, I believe I'm going to go with an adapter remote, specifically, the one found here. http://www.simplism.jp/en/products/iphone/dualo_one_click_remote_with_mic_1/index.html
Now back to picking the headphones, I'm leaning more towards a $50 set of headphones, but can go slightly over. Any suggestions in that price range?
Oct 21, 2013 at 1:06 PM Post #19 of 19
Another update. I found someone on Craigslist that has a set of Sennheiser HD428 new and in box for $20. It wasn't my ideal first set, but at that price, I looked passed basically everything else. I just hope it is the HD428S that has the shorter cable. Not sure what I will do with 10' of cable.
To take care of the remote control aspect, I stumbled across two different gadgets. First is the NoiseHush NS560. It is a bluetooth remote suitable for all phones and even come with their own set of "noise-canceling" IEMs. The other option, and the one I'm getting, is FiiO's E02i Rocky Amp. It is an inline amplifier with the remote buttons. Basically nothing special, but it is basically what I want with a slight boost to SQ.
I'm picking up the HD428 on Thursday, and hopefully the E02i shortly thereafter. I'll keep you posted.
Links:
Sennheiser HD428
http://www.head-fi.org/products/sennheiser-hd428-around-the-ear-headphones-black/reviews
$54.99 (Price on Amazon.com, shipped)
NoiseHush NS560
noisehush.com/stereo-bluetooth/ns560-clip-on-bluetooth-stereo-headset
$24.70 (Price on Amazon.com, shipped)
FiiO E02i Rocky
http://www.fiio.net/products/index.aspx?ID=100000011375372&MenuID=105026001
$25.99 (Price on Amazon.com, shipped)
