dgbiker1
- Jan 14, 2008
I felt the exact same way when I first heard mine. Disappointing bass and painful ~8kHz range (this includes sibilance). My first recommendation to you is to download pink or white noise files and run your K701 with them almost 24hrs a day, giving them an hour rest every once in a while. You'll see them change dramatically pretty quickly.
If you're listening to them straight out of an MP3 or CD player or laptop... don't
These things NEED a good amp. Even my CMOY amp that dramatically improved the Grados couldn't drive these phones properly. My experience with the K701/tube amp was very positive, the tubes help smooth them out a bit.
Finally, these things are notorious for needing long burn-in time. You can expedite the process by running them constantly, but they really sound much better over time. I ran them with pink noise overnight the first day I had them and the bass was much better the next day. About 100 hours in they're no longer sibilant, but still a bit peaky around 8kHz though that characteristic is balancing out. My test record for these phones is Within Temptation's The Heart of Everything. The singer's voice and much of the music seems to be in that 8kHz range, I literally could not listen to the record at any volume when I first got the K701, it was absolutely painful. The combination of burn-in and a better amp has allowed me to listen to the record at the higher end of comfortable listening levels. Until you reach that point, I recommend sticking with acoustic music
