I've been using these for 2 months now, and I'm really happy with them.
Extremely confortable for side sleeping, they replaced my former T-Jays for the night and naps. I wear them cable down, but sometimes i need to put the cable up / around the ear on the ear I sleep on and I just dont feel them. As confortable as the soundmagic PL50 was, but with bass and a smooth signature !
I use the stock medium tips. Tried a few others, including hybrids, but found the stock tips to be the best. They are a little more rigid and bring the best bass. Isolation is also very good with stock tips (but less with other tips).
The cable makes a little bit of noise when wore cable down, so it's not that nice when moving. But for home use, it's really fine (and a lot better than then rigid re-400 cable).
Comparing the sound to other iem I used (as i can, i'm no audiophile) :
As smooth as re-400, with a little more bass, and a bit more power in the upper mid range (but not to the point of being unbearable like the pl50). May be a little more space/soundstage, i would put them between the re-400 (intimate) and the Philips Fidelio S1 (spacious).
Less bass than the t-jays I loved, it was quite a bit of a shock when I switched from the t-jays : the music had a lot more clarity, air and space, more enjoyable (now, I'm used to that and the surprise is gone).
Would love to read more reviews and technical comments about their sound.
Home and night rigs :
