EdipisReks
Banned
- Jul 29, 2004
try putting a drop of superglue on the tip of your screwdriver and then insert it into the screw. wait a couple seconds, and you should be able to pull it out if it's stripped. you can then remove the screw by soaking the tip of the screwdriver in acetone for a few minutes. it should pry right off. i've used this method for stripped screws and it works pretty well.
Originally Posted by DJ Mauler see i tried that but the screws are smaller than a bb, and i dont have a screwdriver smal lenoughm, i found one used for finger skates but the screws seem stripped because they wont turn for the life of me. |
