zeromacro
So you wouldn't recommend the Xonar for a pre-amp? I was thinking about using the Xonar for now as both a pre-amp to my meier corda headfive to headphones AND directly connecting my speakers to the soundcard. Well, at least for now.
Also found a used Magic DAC for around 360 dollars where I live (Korea). Should I just return the Xonar and buy that instead? I can't afford both.
Originally Posted by ROBSCIX /img/forum/go_quote.gif Agreed. You might have wanted to go with a less expensive card to use for a S/Pdif link... There is also devices such as the M2Tech Hiface which many around here give great feedback about, that can be use for S/pdif link to external DAC's. Watch if you go for a USB DAC as some of them use an older receiver unit and are limited to 16/48 other offer full comptibility for the various bit depths and frequencies. |
