survient
- Jan 13, 2010
Hey all, looking for suggestions on a new usb audio interface for desktop usage.
I currently have been running with a hifiman EF2A dac with 6J1P-EV Russian(Soviet) tubes for the past few years connected to a Linux workstation.
It's starting to show it's age with the TRS jack being a little spotty and some minor periodic hissing during playback that occurs from time to time that goes away when I replug the USB cable into the back. It's probably repairable but I imagine it's about time for an upgrade anyway.
I'm neutral about the tubes; I just bought the EF2A on a whim and figured why not.
For sound signature I usually go for flat and accurate. I'm currently using a Beyerdynamic DT-290 headset with a DM-290 mic that hooks up using a 1/4" TRS jack for the headphones and an XLR jack for the mic(the cable is modular).
My setup at the moment is a little complicated. The end goal is to be able to use the DT-290 with the workstation via USB, and be able to jack into an Avaya IP phone using an RJ11 to dual 1/8" TRS adapter(what a normal PC headset would use) plugged into the handset jack.
The way I have it configured right now is to use a Stereo 1/8" TRS to RCA adapter to connect the avaya phone to the EF2A's analog input, and have the USB connection plugged into the workstation. For the microphone I'm using a Behringer U‑Phoria UMC22 pre-amp/DAC which allows me to plug into the workstation via USB. To get the mic into the phone the UMC22 has an analog 1/4" TRS output that I'm running to a Behringer mx400 mixer/amp(4 channel mixer from another project), and then from there to the 1/8" TRS input on the phone handset adapter. From there I'm able to switch between the two sources using the switch on the EF2A.
Definitely a convoluted setup I'd like to simplify but that's where I'm at currently. I have the option of using a soft-phone but I prefer using the physical phone so a DAC with a switchable analog input would be preferred. Technically I can also set up the app on my phone(EC500) to receive calls and pair to my workstation via bluetooth(HFP), but I'd rather avoid that route.
If anyone has come across another device or setup that would be a better fit for what I'm trying to do I'm all ears. Thanks.
