Solude
I need help locking down some options to fix my 'problem'.
I love the Stello, love... love. But its output is way too high when paired with the HeadAmp KGSS. I use my PC as a source and have to run the output at -20dB to get reasonable range on the DACT. Reasonable being steps 1-6 become usable, most material I play at step 4 (8 o'clock).
On a minimalist/ocd mind frame it bugs me that I have to introduce distortion and data loss to be able to effectively use my 'high-end' rig. So I need options for either effectively dropping the output to something usable in the analog domain or DAC options in the sub $1500 range with known low voltage outputs and preferably Stello like sound.
For reference if I use my Zune as a source, at maximum output... the DACT range is about perfect for what I would like. My previous rig was a HeadAmp Reference (GS-X) at unity gain that also paired well with the Stello's output. My understanding is that the KGSS will be at full output at 1V input so that seems to be a good starting place. Unfortunately even though the Stello is advertised as 1.2V, it clearly is closer to 4.8V.
Let me know if you have any suggestions/thoughts.
