kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
what are the part numbers on the output devices (those on the heatsinks) pretty sure they are pnp or p-channel
so this is an upside down version of the srm1/mk2
C101,C102 (still hard to read those numbers) are strictly in the balance circuit. No audio signal whatsoever.
You can replace with 110uf if that is what you want, or 220uf, will not matter in the slightest.
the neon lamp is strictly a safety circuit, and does not (and should not) be replaced.
as far as the cascode current sources, since they will be running at minus voltages, everything has
to turn upside down, so my board will not work. but the general idea works fine. contact jiml for more
information, or search srm-t1 modifications. each current source is a 2 wire device and replaces the pair of load resistors. you need 4 of them. dn2540+ixcp10m90s + 3 resistors each.
here is a more correct version of the circuit. lots of stuff including values and part# still hard to read.
