Would you recommend picking this up at a Home Depot? |
STAY AWAY FROM HOME DEPOT PAINT MAN !!!!!!
really,you will end up doing five coats and still not be happy in the end (looks like i am getting sued now
Do you mean quickly do the corner where the wall meets and then nail it with a roller? |
Kinda.A roller works in large flat areas only so you must get paint into the areas where a roller has no shot.what you do is from every section where two opposing surfaces meet (corners and such) you must use a brush to bring the paint out from the corner to about six inches or so.Far enough to get a good overlap between the brushed surfaces and the rolled surfaces.you also want to get the roller in as tight as possible to the wall.The "texture" of the rooles will not match up to the brushed in areas.The good news is this is not a thing noticed in corners which have shadows anyway.
The suggestion of a good brush is dead on.Either a "Purdy" or "Wooster" in a 3.5 or 4 inch width.Polyester bristle.should run about $20 at Home Depot (saved by the brush !!!!!
Foir the roller do NOT get one of those "all-in-one" kits with the handle,the sleeves,the pan and maybe even a little mini stick extension pole.
instead go for the professional quality Roller Handle and FULLSIZE rolling pan.you can thank me later man,really.Fail to have a big pan that holfds enough paint to tryuly wet the roller sleeve and you will be in for a tough run.
also-1/2 inch knap on the sleeve and wet it well with paint
also ll-get an extension pole for the roller handle,your back will thank you for it later
I thought about painting the ceiling black, but it might be a tad too dark. I'll try and post some pics of the room for suggestions. Thanks for the tips. It's important that it look nice since I will now be dealing directly with clients. |
stay away from dark ceilings unless they are cathedral ceilings and have lighter color trim breaking up the large areas of dark !
(also a real b*tch to work with dark colors and have it look one consistant color)
A dark color will have people ducking as they enter the room due to the illusion of it being low.Dark colors make something appear small,light colors open an area up.
If you must tone down go with either a linen white (almost a tan) or Benjamin moore China-White (the color of chipped china internally)
By "wet edge" i mean work an entire section at a time.A single wall should be cut in with a brush then rolled out immediately before going on to the next.you have maybe 15 minutes or so to get it done correctly if you are gunning for a smooth finish without any shiny/dull areas.
Do not cut in a wall then do lunch !
Best bet is a two person team-one cuts,one rolls
