The Jackal 44
So, I make music, and I was wondering if some of you really high end setup users could do me a tiny favor.
I released a new song with a 32 bit float bit rate, and at 192khz. I know that this can cause artifacts in the music, so I was wondering if a couple of you could simply listen for artifacts. The reason that I did it this way, was that I liked the extra depth that it gave.
You can access it here: https://distribute.avid.com/share/MTAwMDAwNTk1Nzc4
When I distribute it to, Apple play etc... they typically just use the MP3 as opposed to the .WAV file, so that is where my real concern comes in. Did the high bit rate being down-sampled cause any artifacts?
Thank you in advance. I will re-release it with changes in anyone finds something of note.
