Filburt
- Jun 23, 2005
http://www4.head-fi.org/forums/showp...05&postcount=4
I'm going to be performing a similar modification to the D-25 'Turbo' Mod on a Panasonic SL-NP11, which uses the BB PCM60P. This chip is apparently very similar to the PCM66, as when I try to pull up a datasheet for it, I get the PCM66 datasheet. They appear to be pin compatible, and the PCM66 datasheet mentions the PCM60P in a few places, so I'm guessing they are more or less the same chip.
Anyhow, I'm trying to understand what PeterR's modified schematic is actually trying to tell me what to do. If someone could clarify so that I can make sure I do things correctly, it would be much appreciated.
