AgentVX
- Jun 16, 2006
Hey all,
I'm trying to find the best sound card to suit my needs, which are basically to be able to have headphones and 5.1 speakers plugged in at the same time, and being able to simply switch the output in software depending on my usage. From my research, I gather that the Chaintech AV-710 and M-Audio Revolution 5.1 would both be able to do this...so first of all, am I right about that and are there any other candidates that I could consider? (I don't think the Audiotrak Prodigy 7.1 is able to do what I want)
Note that my eventual 5.1 speakers would probably be something low-end so I don't really want to use the headphone jack on them.
Usage would be headphones for personal music listening and the 5.1s for games, movies and a bit of entertainment music when friends (non-critical listeners
) are around. Headphones are currently a pair of Audio Technica ATH-AD5, looking to change probably to Grado SR-60 in the very near future.
So yes I do game a bit but I'm not critical of audio quality when I'm gaming. Here's the main thing that you guys (and gals) can help me answer though...widespread opinion is that the Chaintech requires an amp to get the most out of decent headphones, whereas the M-Audio Revo already has an amplified headphone-out. I'm not looking to spend too much, so let's say I pair the AV-710 with something like a PA2V2. Would this setup be better than a standalone Revo 5.1?
I also understand that the Revo 5.1 has better DACs across the board than the AV-710, but seeing as I'll be using low-end speakers anyway, would it make much of a difference? Any guesses as to how the AV-710's non-Wolfson outputs compare to, say, the onboard audio solutions on modern motherboards?
Finally, are there any other factors in favour of the M-Audio that I may not be aware of? Better API (EAX and the like) support or something? Specs for the AV-710 are quite limited so it was a little hard to compare them head-to-head.
Thanks in advance for any advice/opinions.
