Need replacement for Nokia n900 earphones
Aug 5, 2010 at 6:32 PM Thread Starter Post #1 of 5
deadman_uk
The earphones that came with my Nokia n900 are faulty (left earbud has very low sound and I also lost one of the gel cushion thingys). I live in the UK and need of a replacement under £30. I was thinking about the Sennheiser CX 300 II or Sennheiser CX 400 II but some customers say they are poorly built (but sound good). I can get the CX 300 II for £12 from Amazon UK so would you recommend I do this? or are there better options? I really don't know much about earphones but as long as they sound decent (ish) and don't fall out of my ears, I am fine.
Thanks for any help. I made my headphone purchase based on opinions here a few years ago (audio-technica ATH-A700) and I am glad I came here for advice.
Aug 7, 2010 at 3:37 PM Post #3 of 5
asrphani
radiopaq jazz,head-direct RE2 and soundmagic pl30 fit your budget very well..But you need to search,read reviews like this-
http://www.head-fi.org/forum/thread/478568/multi-iem-review-95-iems-compared-elago-e3-jvc-ha-ebx85-added-08-04
