Arainach
- Jul 25, 2005
This might've been true in the Pre-XPSP2 days, but it's really not the case anymore. Nowadays, a patched Windows box is as secure or more secure than any other consumer OS out there.
Originally Posted by Omega /img/forum/go_quote.gif If you have a Linksys WRT54-soemthing, you can try installing one of the alternative firmwares like dd-wrt. That can solve a lot of stability issues. If you are going to use your computer for work, DO NOT run Windows and connect directly to the internet, or via a switch to the internet (which is basically the same thing). As majid asserts, your computer WILL be compromised. If you must use a software firewall only, the built-in Windows firewall is very weak. Get an old version of Kerio Personal Firewall or a new version of ZoneAlarm. If you pick the right version, they are/were both free, so no excuses. Is your connection drop problem occuring on a wired or wireless connection? If you are having problems with wireless, the first thing would be to change the channel...and then see if going wired can solve your problems. |
