Azure
- Jun 13, 2004
What about the A500s for $99? They don't require an amp at all and have enough bass to vibrate your ears and rattle. They seem to be widely regarded as having a lot of bass.
Originally Posted by NewCents05 yea you guys are just recommending stuff not really in my price range so i dunno those koss ones def wont make more bass than the sony clip ons i have now. edit: and the only reason im "wazzing" up in bass on my eq is cause my headphones kinda suck without it... i probably will turn up the bass but not the bass boost cause it just distorts it |
Originally Posted by Carl If you get the 770s, at least you'll be sorted for quite a while. Get anything cheaper and you just get bass flab, rather than the sort of bass that you'll enjoy listening to. |
Originally Posted by smeggy Ok, if you can live with open cans and maybe a little discomfort I think a set of Grado SR 60's are in your future... BEHOLD! http://www.headphone.com/guide/by-he...rado-sr-60.php These should satisfy your bass craving with a little EQ, not distort unless you really pound them and last a long while, and they cost under a ton. Well regarded around here and may even help to cure you of this odd bass affliction. |
Originally Posted by Azure What about the A500s for $99? They don't require an amp at all and have enough bass to vibrate your ears and rattle. They seem to be widely regarded as having a lot of bass. |
Originally Posted by sxr71 How do you know he isn't looking for what we call "bass flab"? |
Originally Posted by NewCents05 yea well what are the a500s like what brand so i can look it up. im not really up to date with all these headphones otherwise i wouldnt be asking you guys. and What is bass flab what about the AKG K301 are those any good? |
Originally Posted by Azure A500s are the audio-technica ATH-A500s. You can buy them from audiocubes: http://www.audiocubes.com/product/Au...eadphones.html I'm not sure what's up with the review that gave the A500s 2 stars for not having any impactful bass. The A500s excell in 3 aspects: 1. Comfort 2. Wide soundstage 3. Bloated bass So, I don't know what the guy's deal is. Maybe he came from DT770s or PS-1s? |
