Koukol
- Feb 2, 2014
Hello,
I have a set-up which includes a Marantz CD player running through a Little Dot III amp pushing HD558 and K601 HPs
I'd like to add something in the chain to customize the sound with each CD recording (take away annoying frequencies and add bass when needed)
I thought I'd try using my Mcintosh Pre-amp with its 3 knob EQ but while I can get desired tones the hissing drives me nuts.
So, I'm wondering if there's something magical that can eliminate the hiss or should I take the Pre-amp out of the mix and put an equalizer in it's place?
If I go by the way of an equalizer is it important I get an Analog EQ ?
I assume this is an analog Equalizer since it has no digital inputs, yes?
http://www.amazon.ca/gp/product/B000E1PXCK/ref=s9_simh_se_p422_d0_i2?pf_rd_m=A3DWYIK6Y9EEQB&pf_rd_s=auto-no-results-center-1&pf_rd_r=11B5NEB2T35AATE6VCXF&pf_rd_t=301&pf_rd_p=478281791&pf_rd_i=home%20stereo%20hiss%20removal
Cheers.
Cheers.
