Need Help with scratchy volume knob on headphone amp
Aug 21, 2019 at 11:38 PM Thread Starter Post #1 of 11
JBThazard
I have the Maverick Audio Tube Magic D1+ and for a while now the volume knob creates a crackling or scratching noise when I turn it. I tried a lot of different advice, like turning the knob with the amp off or opening up the case and dusting it out, but none of it has worked.
I think the problem is more structural as I've noticed that the little plastic base inside the amp where the knob is connected to is a little wobbly. The volume knob itself is also a little wobbly, so I think that the scratching noise is being caused by the knob coming into contact with something it isn't supposed to.
Any advice on what I should do? I haven't tried contact cleaner but I don't think that will help. I don't know how to remove the knob from the amp so advice on doing that would be great as well.
Aug 22, 2019 at 7:23 AM Post #4 of 11
Haven't tried any contact cleaner, I want to unscrew the knob from the Bk100 and see if I can clean it or screw it back into an optimal position
The symptom definitely sounds like a dirty contact .
Aug 22, 2019 at 12:14 PM Post #5 of 11
So I borrowed some contact cleaner from a neighbor and try to see if that fixed the issue but it didn't. I think there's less of a "static" sound now but the crackling noise still happens when I twist the knob, still looking for someone to teach me to remove the knob and get to the bottom of this
Aug 22, 2019 at 6:47 PM Post #6 of 11
How did you apply it? Did you take the case top or how else it comes apart off ?
Aug 22, 2019 at 7:03 PM Post #7 of 11
Yes, I removed the top lid of the case and sprayed the cleaner around the BK100 connector thing that's attached to the knob. I noticed that some static was reduced so it definitely cleaned something out, but I still get that right channel cut-off or the scratching noise while turning in certain spots
Aug 23, 2019 at 10:12 PM Post #8 of 11
Try changing the tube. What you describe can be a dirty volume pot. However, it can also be the tube oscillating. With a tube in the circuit, oscillation very often sounds the same as a dirty volume pot.
Aug 23, 2019 at 10:43 PM Post #9 of 11
I see, never considered that. I've had the same tube for about 3-4 years now, could it be getting too old? I was actually planning on upgrading to a Tesla 6CC42 pretty soon
Aug 23, 2019 at 11:14 PM Post #10 of 11
Yes, it could be getting old. However, you should always have spare tubes to check symptoms you may notice in the life of an amp based on tubes.
Don't buy a really expensive tube thinking that may solve the problem. You may be disappointed. I simply pointed out another cause of a scratchy volume pot. We're all still just guessing.
Aug 23, 2019 at 11:15 PM Post #11 of 11
A scratching sound often results when adjusting the volume knob if there is some DC offset voltage present. Not so often just a dirty pot. Try a different tube and see what happens.
