Halide
- Oct 13, 2003
I got the 3.5mm male right-angled jacks from switchcraft with canare miniature star quad cable.
I need tips on :
1- How much do you cut back on the outer sleeve (just enough to be crimped and inside the casing?)
2- How do you remove the braided fine-metal wire sleeve
3- How much do you strip off of the individual wires
4- Should I solder both white wires to the ground of the connector, or just cut them short
5- How do you crimp the wire (before soldering? after? and what tool?)
i know these are some REALLY newbie questions, but I just don't like how mine turned out... It works, but it's sloppy, and I also accidentally cut into the outer sleeve on one side which may lead to a problem in the future
I need tips on :
