Lore
- Sep 9, 2012
Hi!
I just got my HRT Headstreamer and I already have some questions about it...I'm using Windows 7 + foobar2000. So:
1) foobar2000: I've set up WASAPI and selected "WASAPI (push) : Speakers (HeadStreamer)", 24 bit output, disabled ReplayGain...is this correct?
2) How should I set up the Windows audio dialog? Should I check "Disable all enhancements" and set 24bit/96 kHz as the default format?
3) When listening to FLAC files with foobar2000, which volume control should I use? The HRT Headstreamer has a digitally-controlled analog volume attenuator... "(the master digital volume slider on the host computer causes the analog circuit inside the HeadStreamer to adjust the volume up or down)"
Thanks!
Thanks!
