slindeman
- Jun 25, 2001
I'm looking for help determining two things, Comfort and Isolation Level of the following circumaural closed isolating headphones:
AKG K271S
Beyerdynamic DT770
Philips HP170
Sennheiser HD250II
Sennheiser HD280Pro
Ultrasone HFI-650
As a standard for acceptable comfort, I would cite the following: Sennheiser HD570/590, AKG K401/K501, Beyerdynamic DT831/931, Stax Omega II.
Those that don't make the cut for comfort include: Koss Pro-4AAT, Sennheiser HD580/600, Stax SR404, Beyerdynamic DT250, and every supraural headphone.
Any comparisons you can make with the fit of the above headphones to others that I've tried would be very helpful. FYI I've worn the following circumaural headphones: Senn HD500/545/570/580/590/600/HE90, AKG K401/501, Beyerdynamic DT250/831/931, Koss UR20/Pro4AAT, Stax SR404/OmegaII, Sony MDR-CD1000/CD3000.
I have stick-out ears that are somewhat large and very sensitive to pressure. If the headphone pad holes are too small, or too shallow, they will present problems. I'm looking for isolating headphones for 2+ hours use. If I've left any candidates off the list, please recommend them. I'm looking at cheap as well as mid-priced headphones -- I may buy one of each. Info about sound quality is welcome, but not essential since these will not be my main music headphones, but will be for television, computer, and background music. Presently I use HD570 for this purpose, but would like to try isolating headphones for a change.
Any help you can give me will be very much appreciated!
AKG K271S
Beyerdynamic DT770
Philips HP170
Sennheiser HD250II
Sennheiser HD280Pro
Ultrasone HFI-650
