tmann
- Apr 8, 2003
I received new gumsticks for my D-777 (HF-A1U industrial batteries, from tnrtechnical.com) These are the "equivalent" to Sony NH-14WM. However, the body of the battery is a tiny bit taller, so that the contact point ("bump") on the positive side of the battery is almost flush (does not stick up as much as the Sony NH-14WM that I am replacing). After trying the new batteries with no luck, I noticed in the battery compartment on the D-777 that the contact points on each positive side are recessed (interestingly, in a different way for each side), so that the nearly flush contact point on the new batteries does not contact the metal in the compartment. I can pry the metal out slightly on the right side, but on the left side this does not seem possible.
So, I am guessing that this is a way to force people to buy the ridiculously overpriced Sony batteries (which are "customized" with a taller contact point to fit in the compartment)
My question (finally) is: Has anyone found a way to use batteries other than the Sonys in the D-777? (Ones from minidisco.com or iriveramerica.com, for example). I am wondering if "branded" Sanyos or Panasonics might have the same configuration as the original Sonys, as opposed to the "industrial" ones I bought, with no label. (Shot in the dark here, I know)
Any help is appreciated!!
