VNandor
- Oct 17, 2014
As the title suggests, I want to measure my ELC so I can do a better job at equalizing my headphones. But for this I need to have a good speaker system to start with and a good methodology to take the measurements.
The thing is, I don't have a multi-thousand dollar Hi-Fi system to start with nor the knowledge to conduct such experiment but I hope I can tweak the speakers to be good for this particular task and to get some help with it. I have access to a pair of Orion HS501s and a pair of Jamo 708s (they are floorstanders and I don't have any room treatments) and a pair of nearfield speakers taken from a cheap Sony mini-hifi system.
The most obvious thing I can do is to get a device which I can use to calibrate the speakers to flat. Problem is, I don't have the slightest idea of how such a device should look or if it even exists. I imagine something like this could do the trick (with a calibrator if needed) or am I totally wrong?
An other thing I'm concerned about is the distortion of the speakers. I mean, Let's say I'm measuring 90dB SPL while I feed a 100Hz sinus to the speaker but in reality the speaker makes a 80dB SPL 100Hz sinus and the rest is just distortion/harmonics? How much could that skew the results? Is there a way to compensate against it?
And then, there are the room acoustics of course with standing waves, resonances, who knows what. What should I pay attention to? Is it something to worry about as well?
And probably the most important thing is how I'm trying to measure and EQ. I'm planning to go from ~20Hz to ~20kHz (well, maybe only like 50Hz to 15kHz due to the quality of the speakers) note by note (major seconds), and putting down how much I have to boost or reduce the signal and make an EQ correction curve out of it. the 20Hz-20KHz note by note measuring would take about 60 steps if I'm not mistaken so it wouldn't take too much time and would be reasonably precise. Any thoughts on that?
After I made the correction curve, I would sit down where the microphone was and start playing sine notes (at my normal listening levels) and apply EQ to make them sound equally loud. However I'm not quite sure how I could remain consistent with my judgement though. I imagine it would be easier to go up by octaves instead of seconds because the loudness differences would be more obvious. And then maybe doing thirds between octaves to make it a bit more accurate but I doubt I could remain consistent with too similar pitches.
So with that method I would get a pretty good ELC depending on how good the devices I used were and how attentive I was when I made the loudness-matching.
I would later use that ELC curve to add it into my headphone playback-chain and do the same loudness-matching thing and then remove the ELC curve.
To sum it up my questions are: What can I do to make the measurement as accurate as I can? Any obvious flaws I haven't thought of? Am I deluded to think I can end up with reasonably good results? Anything else to add?
