WhenKittensATK
Previously known as krazyxazn
- Apr 28, 2009
I recently purchased a Bottlehead Crack, however I don’t plan to use my speakers and all of my headphones with it. So, I’m thinking I’ll probably need to build a DIY Switch Box to consolidate all the inputs and outputs to avoid cable swapping. I have no experience with designing or building electronics, so I’ll need your help with that.
I drew a diagram of what I’m hoping to get out of the build. I hope it makes sense. I basically have two inputs, Audio-gd NFB 15.32 DAC and Bottlehead Crack. I want to be able to toggle between the NFB 15.32 and Crack, like an A/B switch. I also want to be able toggle output to my speakers (only turned on, when in use) and 4 headphones.
Sounds simple, right? I honestly wouldn't know. So this where I need your help:
- Do I just buy single solid/stranded copper cables for the internal wiring? If so, what kind?
- Is there something I need to solder the 3 way splitter or can I just solder 3 ends of the wires together?
- What would I need to wire the 2 input / 1 output toggle switch (Probably will mount it to the front of the case)?
- Any suggestions of parts for the RCA, headphone jacks, and rotary switch?
