Firam
- Jan 20, 2005
I've been looking at http://www6.head-fi.org/forums/showthread.php?t=166545 and I know what I need to do but not what supplies to do it.
It is suggested that I need 2 caps being anywhere from 1uf-44uf. I have a limited understanding of which to pick. I would think that a 44x capacitance difference would make a difference. I think I can use either electrolyte or film right? Then there is the issue on what voltage, does it matter? Is this a important part of the amp and would it be best to buy a more expensive cap or will a cheaper one do just as well? There are just so many types, it makes my head hurt.
The resistor should be 100k. Does the type matter? What about the wattage?
Finally the wire. I want something like 22-24 awg right? Somthing like this? http://cgi.ebay.com/50-feet-stranded...QQcmdZViewItem
