happyangryhappy
- Feb 10, 2006
I hope this forum is right.
Anyway, I am looking for a new integrated amplifier. I am replacing an older Marantz 2230 with some issues but that sounds good, so I do want something that is a move upwards in performance. I have read many reviews and am thinking about the NAD 320 BEE or the the Cambridge 640a - although used rotel, arcam, outlaw audio ect.. are not out of the question either.
My budget would be around $500 (used is great); phono stage is good, but not mandatory; and as I said I want it to be a step up from the Marantz. Is this possible? And if so, which one (or other) do you recommend? Also, vintage is OK as well.
In other words, I trust the opinions on Head-Fi more than other online sources and am asking what you recommend I get.
Thanks.
Thanks.
