headchange4u
- Jan 3, 2005
I have ordered several different brands of 68-75 ohm resistors that I am going to test for their sonic differences in the application of a 75ohm conversion cable.
I would like to etch my own PCB test board. I just need help in the layout of the PCB.
I will be using Switchcraft PCB mount jacks that my headohones will plug into and that will go into a Neutrik 3.5mm plug that I will mod to fit on the board. I also have some sockets that I am going to use for the testing of the resistors. The socket solder into the board and they have an open top that will accept the lead of the resistor. This way I will not have to solder a test resistor into the board and then desolder it to get it back out. I had also thought about using one of the sockect used for mounting an OP amp. This much I can figure out on my own. It's pretty simple design.
I have now decided that I would like to incorporate a seletor switch, preferably something I can pick up at Radio Shack. I would also like to mount some Vishay resistors to the board, which is what I normally use in my conversion cables. The selector switch would be used to switch the signal between the test resistor and the "stock" Vishay resistor for a really quick A/B comparison with out having to plug and unplug a cable. One reason that I want to do all of this on a test board is because I don't want any cabling in the equation to color the sound I am getting throught the resistors.
I hope this makes sense and someone here could help me.
