NilsOlav
- Sep 12, 2014
Hello folks. I have a pair of KEF Q300's and an Emotiva Mini-x a-100 amp connected to my PC. I've noticed a slight pull towards the sound of the left speaker since I had them. That speaker sounds slightly louder with more detailed sound. When I switched the speaker wire, the right speaker was then the louder speaker. I tried fixing this first by buying new speaker wire, but the problem persisted. I also ordered a new RCA to 3.5mm adapter to see if that is my problem, so once that arrives in a few days I will know for sure.
I additionally have noticed that once in a while, my sound will cut out and my Windows will alert me that "an audio device has been unplugged" and then the sound will cut back in a few seconds later. So, I figure this is a problem with my 3.5mm connector, or a problem with my onboard sound.
I have been planning to buy a sound card anyways...so, if this problem is not solved with the new RCA to 3.5mm adapter, do you guys have any sound cards you would recommend to ensure I have quality sound and a good connection? I also am looking to produce music, and the sampler I'm looking to buy has "RCA out and a quarter-inch line out". So, if I can hook up both my speakers and the sampler to this sound card, that would be ideal.
