goodyfresh
- Jul 29, 2015
So basically at this point I am stuck between the ATH-M50Xs and the HD 598s so I am going to list the pros and cons relative to each other here:
Audio Technica ATH-M50X ($169):
Pros:
Subtle
Leather earcups (Comfortable, look nice)
Easily portable if needed
Cons:
Closed
Leather earcups (Not very breathable, sweat)
Extra Bass
Sennheiser HD 598 ($150):
Pros:
Open
Valuer earcups (Breathable, comfortable, look nice)
Wider soundstage
Better treble
Cons:
Valuer earcups (Collect lint, dirt, etc.)
Ends in a 1/4" plug instead of 3.5mm (need to buy another cable)
Flashy/gaudy (Not too important since these would stay by my computer at home)
A little lacking in bass (?)
If I'm not mistaken, while the cable that comes with the HD598 does end in a 1/4", it is packaged with a 1/4"-to-3.5mm adapter you can screw onto the end, so THAT at least shouldn't be an issue! Quite honestly though yes, the HD518, 558, and 598 do mids and treble VERY well, but are all somewhat lacking in bass, which tends to be a more common issue in mid-range open-back hp's than closed-back ones.
Also, if you're using your computer's onboard sound-card, then yeah, it's probably bottom-of-the-bucket crap like most computer manufacturers use, and poorly isolated and implemented to-boot. And so rather than JUST an amp, it would probably be a good investment to get a good USB-plug-and-play DAC/AMP combo, which should give a VAST improvement over your onboard sound. If not that, at the very least learn how to use a player like Foobar2000 to send WASAPI or ASIO output (the latter by downloading something like ASIO4ALL) directly to your listening device, rather than allowing things to be muddied and crapped-up by the internal windows mixing in your soundcard. If you want to learn more about things like Foobar2000, WASAPI, and ASIO, you can search for them in the forums here. Basically, WASAPI or ASIO, in a player like Foobar that supports them, will send bit-perfect output directly to your device, without any software mixing along the way to muddy-up the sound which tends to be the main issue with sound quality in Windows computers. Anyway, supposedly some of the very best cheap ones (all can be found for under $100 on Amazon, and a couple of HiFiMeDIY's can be found as cheap as 50, although you don't want to totally cheap-out and get their so-called "Tiny" DAC model that costs like 25 bucks, you def want to spend 50 bare-minimum) are the Fiio E10, Fiio E07K, the various offerings from HiFiMeDIY, the Schiit Modi, and the SMSL SD793-II. In the audiophile world, it seems as if external sound-cards are frowned upon as compared to external DAC units without a full-blown sound-card. Also, a buddy of mine and I had a poor experience with one of Creative's external Sound Blaster cards. . .it pooped out and stopped sending proper sound to the left channel after a few months of use.
