Nak Man
- Aug 6, 2004
Don't know if this is the right forum to post my question.
Just got a subwoofer that's humming loudly - sounds like ground problem:
• touching heat sink reduced the noise but still audible.
• turning 'phase control' varies hum noise.
• touching rca input made the hum louder.
Tried with no success:
• reversed AC plug, using groundless 'cheater' adaptor
• connect / disconnect rca input from preamp
Any hint what area should I be checking or looking at ? Ground is connected to chassis / heatsink but not to high / low level input's ground. I don't have the schematics but it's using something like off-the-shelf or generic sub amp.
Thanks much in advance. =)
