attilais
- Aug 18, 2002
My room is just near an express way, and there are trucks roaring even at 1 am (although I'm on storey 10![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Currently I am using an AKG K-501 bought three months ago. I like it pretty much, except for a little lack of bass for symphony. But it's completely open...
I think I should change to a closed one. I need ur advice on these problems:
(1) Is closed headphones suit for long-time listening, say, 2 hours? Someone told me that they tend to make you uneasy.
(2) If I use a semi-open one such as DT880 at normal volume, will people sleeping 2 meters away be disturbed?
(3)The only closed headphones I know are Beyer DT831 and DT880 (semi). I need some recommendation on more brands and models. I only listen to classical, and mainly symphonies at this time. BTW, I like the sound of K501 pretty much.
Sincerely thanks!
Sincerely thanks!
