phantom1
- May 30, 2013
At the point where the hardened jack turns into the soft cable, the cable is starting to come apart and show the wiring inside. Sound quality has not been affected, but I want to do something before the wiring presumably starts to come apart as well. Is there any way to replace the cable? Or do I have to send it to Logitech under warranty?
