PhilS
- Jul 17, 2004
I bought an Acme upgraded outlet for my audio system, and I have a question about installation. The outlet I am replacing has two black wires and two white wires. The black wires go into the top two holes on one side of the back of the outlet and the white wires go into the top two holes on the other side of the outlet. The bottom two holes on each side of the outlet have no connection.
The outlet I am replacing has two screws on each side, one on the top and one on the bottom. Do I connect the two black wires to the top screw on the one side and the two white wires to the top screw on the other side, or do I connect one black wire to the top screw and one to the bottom, and the same with the white wire? Thanks in advance for you help.
