Need help in choosing a HeadPhone
Jun 14, 2013 at 9:20 AM Thread Starter Post #1 of 3
MadGary
Hello,
I am planning to buy a new pair of headPhones.
My Budget is under Rs. 1000 INR
I narrowed down to the following ones:
Creative EP-630 - http://www.flipkart.com/creative-ep-630-earphone-in-the-ear-headphone/p/itmd4vsffxg5uza6?pid=ACCD4VSYZH9RPHGM&ref=001132b3-2182-4f5f-b68e-5f0ecd007446
JBL Tempo In Ear Headphone - http://www.flipkart.com/jbl-tempo-ear-headphone/p/itmd7gyydvbxjuct?pid=ACCD7GYXJHEWNAQG&ref=001132b3-2182-4f5f-b68e-5f0ecd007446
Sound Magic ES 18 - http://www.flipkart.com/sound-magic-es-18-headphone/p/itmd8dggvtjvyyek?pid=ACCD8DGGXSGTD6CM&ref=cd863a58-35c6-47d0-ad61-b089e4b0757c
Panasonic RP-HJE120E-K - http://www.flipkart.com/panasonic-rp-hje120e-k-in-the-ear-headphone/p/itmczc2meuqz2hjr?pid=ACCCTUZPMZXZRBA6&ref=d4800099-4d32-493b-bbbd-0c032c604835
and lastly
Philips SHE3570BK - http://www.flipkart.com/philips-she3570bk-in-the-ear-headphone/p/itmczyh3xpgpyck8?pid=ACCCZYHYHFZPESPC&ref=d4800099-4d32-493b-bbbd-0c032c604835
I have used Creative EP-630 previously and I must say for the price the kind of sound quality it produced was great.
Was thinking if I should go for the same or one of the others mentioned above.
Any inputs are welcome.
Also if you are recommending a headphone, please let me know if you have personally used it or no and the reason why you would recommend it.
I listen to different genres of music: Mostly Rock (Melodeath, Progressive, alternative, Power Metal, Folk Metal, industrial, symphonic metal and so on..) and Hip-Hop, Rap, DubStep and a little bit of everything else like pop, funk, R&B, Bollywood, punk, trance, etc...
Thank You in Advance for all your inputs :)
Jun 14, 2013 at 10:48 AM Post #2 of 3
reeshahn
Hello,
and lastly
I have two questions:
1- Are you sure this website is not selling fakes? Since the most expensive one in your list is Creative EP-630 and it is only around 10 Euros if xe.com was giving the correct exchange rate.
2- Wouldn't you consider going a little high in your budget but get a better pair than these ones in your list? If you used Creative EP-630 previously I think you should be tired of it and maybe it is time to upgrade to a better music quality.
Jun 14, 2013 at 11:16 AM Post #3 of 3
MadGary
1) Im pretty sure the website sells original products.
2) I don't mind going a little over the budget as long as I am getting a good pair of HeadPhones.
Did you have any Suggestions?
