TrantaLocked
- Mar 30, 2011
If someone out there has the IE6 and have heard many other in ear headphones, tell me what set of in ear headphones you think sounds most like the IE6 with these exact EQ band settings (this is in rockbox on a sansa clip+):
32 Hz - 0.5 db
64 Hz - 1.5 db
305 Hz - 0.5 db
1000 Hz + 0.5 db
2000 Hz + 0.5 db
3200 Hz + 1.0 db
4600 Hz - 2.5 db
6500 Hz + 2.5 db
8800 Hz + 3.0 db
I will be getting a phone to use spotify with, but unfortunately android phones are not built in with EQ settings and apparently EQ apps don't have band customization which makes them useless. The IE6 sounds pretty bloated without this EQ and I either need a new set of headphones that have this sound native, or somehow get a proper EQ app for android
The Phillips Fidelio S2 (http://www.innerfidelity.com/images/PhilipsFidelioS22013.pdf) comes close to what I BELIEVE I am listening to with the EQ on my IE6, but unfortunately it has a mic control which automatically makes me think the headphones weren't designed specifically to have good sound quality.
By the way, here is stock IE6: http://www.innerfidelity.com/images/SennheiserIE6.pdf
32 Hz - 0.5 db
64 Hz - 1.5 db
305 Hz - 0.5 db
1000 Hz + 0.5 db
2000 Hz + 0.5 db
3200 Hz + 1.0 db
4600 Hz - 2.5 db
6500 Hz + 2.5 db
8800 Hz + 3.0 db
