Originally Posted by RYCeT /img/forum/go_quote.gif
Coming from Windows, I always partition my Hard Drive and separate my personal files (mp3, doc, pics, etc) from my windows/program files. Since I'm going to install Xp pro on my macbook, I'm going to separate my hd to 4 partition.
1. for OSX system
2. for OSX personal files
3. for Windows system
4. for Windows personal files
so what do you think guys? Is it necessary to do that?
It's not necessary to do this on a Mac. One of the main reasons for keeping personal files so separate on Windows is because you reinstall the operating system every 6 months or so, and it's helpful to have your personal files separate. But on OS X, all your personal files are constrained to be within your home folder by default... think of your home folder as a separate partition, just in a directory. If you want to ever reinstall OS X (I've never done so, btw, except for upgrades), just make a copy of your user folder first. That backs up all your user files. The "Archive and Install" feature when a new version of OS X comes out does this automatically.
I'd just keep a Mac partition and a Boot Camp partition, personally. If you want two separate Windows partitions, one for the OS and one for files, you could do that too. But I see no reason to have two Mac partitions.
Re-organizing Applications.
I read that Apple suggest putting all programs under applications folder. My application folder looks messy right now, I prefer to re-organize them under sub-folder on applications. Will it cause problems? |
You can always move around third-party applications. You can also move around Apple apps and they'll still run, but it used to be in older versions of the OS that moving around Apple apps could make the system update thing not be able to find them. I'm pretty sure that's fixed in Leopard, though.
Un-installing programs.
I just want to make sure here, all I need to do is dragging the program to the trash can, isn't it? Is there anything I should do? |
Yes, that's the great thing about OS X. It makes trying out new software much more friendly. Note that, like Windows uninstallers, there may be a few configuration files in your Library folder left over after you drag a program to the trash. This is by design, so you don't lose any data when uninstalling programs. But if you're obsessive and it bugs you (it doesn't bug me, I think it's the right behavior), try applications like AppZapper, which cleanse your system of all related files when you uninstall.
System Maintenance
Should I do system maintenance on Mac (Defrag, disk Scan, etc)? |
No. The system automatically defragments files below a certain threshold on your boot hard drive as you use it. There's no need to run these kind of maintenance tools. If you think something is wrong with one of your hard drives, run Disk Utility in your Utilities folder, click on the partition or drive in question, and click Verify. It can repair too if it finds any problems.
Antivirus & Firewall
Well, I learn that you don't need antivirus on mac, how about Firewall? |
There is a firewall in System Preferences -> Security. You should turn it on. I would also recommend clicking "Advanced" and turning on Stealth Mode.
