LNuneek
- Feb 14, 2015
I'm looking for replacement ear pads for the Yamaha RH-5Ma. I realize there are no official replacements from Yamaha, so what other ear pads will fit?
I would be very happy if I can find pads that fit that are made from something other than that cheap sprayed on pleather type. I'm not too concerned about the sound changing with different pads.
The recommends would have to be something I can get from an on-retailer that ships to Canada. Amazon.ca is fine. Would really appreciate the help!
