Airwolf
- Aug 19, 2012
I have a JDS O2 amp that I have been pairing with a Sound Blaster Recon 3D through the 600 ohm port on the card. One of the NJM4556A op-amps blew out and cracked in half. I posted about this in the amp forum (http://www.head-fi.org/t/736374/jds-o2-blew-an-op-amp-pic-inside-question-regarding-replacement). After being contacted by a very helpful person on another forum, I was made aware that the HE-400's are basically doubling the rated power output of the NJM4556A op-amps at my listening levels, which is the most likely reason one of them blew.
That whole can of sensitive can of worms aside, it appears that I am in the market for an amp that is better suited to the HE-400's power requirements. This very nice person, who shall remain un-named, gave me the following advice after some calculations:
I honestly don't have a ton of money to spend and was hoping to keep my purchase in the sub $200 range and a used amp is perfectly acceptable to me. Can anybody recommend an amp that would fulfill these power requirements? My only other requirement is that it is not a tube-based amp just because it will be hooked up to my computer and I am wanting something that I don't need to worry about warming up and turning off. If it is more economical, I honestly wouldn't be opposed to using a cheap home theater receiver if it would have absolutely no problems driving the HE-400's.
Thanks!
What you want to look for is amp rated for what your headphone would require to hit 120dB. That is 4.4Vrms output swing while supplying 127mA of output current, and ideally *continuous* and not just peak.
Thanks!
