VeerK
- Aug 22, 2013
Hey all,
While I don't consider myself an audiophile of the caliber of the community here, I know good sound when I hear it. I've had home theater equipment for years, and I have a music collection of hundreds of FLAC albums, so my discerning ear is trained by the quality of the equipment I have been using.
On to my dilemma, I recently built my own computer with some top notch parts and have been enjoying immensely. However, I prefer to and constantly use headphones as my sound solution, as space and other constraints prevent me from using my HT set-up with my computer. My headphones are the Senneheiser HD 598, and considering that I have to connect it directly to the 3.5mm headphone jack on the back, I have no doubt that the 598's will destroy that jack due to the size and weight of the connector. My solution was to use the SPDIF port which seems a lot more solid and causes me far, far less worry. Thus far, I have been using an Orei DAC that was supposed to be good, but it cannot handle anything but LPCM and has an absolutely horrid buzz when there is no sound blasting that is actually starting to hurt my ears.
TL;DR
My question is: what DAC should I get, and is there anyone that can handle more than just LPCM, so I can watch Blu-ray movies? Also, how much sound quality am I losing by using an external DAC? I just blew a lot of cash into building my PC for work and play, so I really can't afford an expensive DAC and the Orei was only $30, so anything in that range. For arguments sake, I have a limit of $100. I know a lot about computers, and I am a videophile, but audio is something I never truly delved into for the sake of knowledge alone, so I was hoping you fine folks could help me out .
TL;DR
