ABXG
- Apr 6, 2008
Hello, I recently purchased a FiiO E9 and I am noticing something a little disconcerting. With my headphones plugged directly into my D2X I can crank the volume on my system to max and not hear any static through my headphone. If I plug my Headphones into the E9 and do not attach the E9 to my D2X I can crank the volume on the E9 to max without hearing any static.
The problem comes when I actually have my system hooked up the way I have described in my signature (D2X -> E9 -> HD595). If I turn the volume up on the E9 much past 1/4 of max volume I can start to hear static through my headphones. This suggests to me that the cable I am using to connect my D2X to my E9 is crap. I guess I shouldn't really surprised by this considering I bought the 1m long cable for <$1. I unfortunately did not expect the cable to make much of a difference considering my system is far from high end.
I am wondering if anyone can suggest a decent 2m long 3.5mm m/m cable for my system. I am not exactly made of money (student) so I can't spend something crazy like $100 on a cable. I just want something that will improve my audio experience by (hopefully) eliminating the static.
Thanks in advance for any help.
