willne1
- Nov 12, 2008
I'm trying to desolder some capacitors on a board. I turned the heat on my Hakko up to 800 deg. and still can't get the solder to melt. what am I doing wrong?
Originally Posted by SiBurning /img/forum/go_quote.gif Nope, it's not always easy. It's highly unpredictable what problems might turn up on an unknown board. I recently had a scare and (wrongly) thought I ruined a board, so I gave in and bought an expensive desoldering station with built-in vacuum. Call me a wimp, but I've had to repair a couple of boards I messed up before. Don't want to do that again. One thing you definitely don't want to do again is turn up the heat and keep it there if something isn't working. That's a sure way to lift a trace or worse. If you have to wiggle the cap side to side while moving it out bit by bit, you're better off just lifting it just enough to cut the lead and toss the part. |
Originally Posted by les_garten /img/forum/go_quote.gif Hi, I was looking at MPJA and they have a "Cheap" desoldering station for around $115. Which one did you buy? Did it make a huge difference over a solderpulit? If so, how does it do it so much better/ . |
Originally Posted by B00MERS00NER /img/forum/go_quote.gif I believe if you ever used a vaccum desolder you would never even think of using any other method, especially for components on pcb. |
Originally Posted by les_garten /img/forum/go_quote.gif Most likely Junk, but these can be had pretty cheap. Digital Desolder Station, ZD-915 - [4652] - (Soldering Soldering stations, accessories and rplacement) - Manufacturers: Zhongdi - Komerci - Shop - Electronics and more ... Zhongdi Manufacture Co.,Ltd. . |
Originally Posted by B00MERS00NER /img/forum/go_quote.gif I've run across that one but it seems it had a different manufacturer, i just found this on ebay, this is ideal, great price. UNUSED PACE PRC2000 PRC 2000 SOLDER, REWORK & REPAIR - eBay (item 150332526671 end time Mar-21-09 23:19:27 PDT) yeah, flux is your friend |
