hedmaster
- May 5, 2009
Hi guys, I have a pair of DT880s that are only a few months old. A few days ago the right side went out on me. A few minutes later it came back on, and has been on and off since.
Probably a loose solder joint, simple enough-just open it up and solder it back, right?
But, would I be better off sending them in and getting them fixed, or possibly replaced? They are only a few months old, and I could go without them during the time it takes to repair them.
What do you think? Is it worth it to send them in, or should I just solder them on my own and save the hassle?
Also, if I did re-solder, does that void the warranty? I only scanned their warranty policy, so if anyone knows for sure, that would be helpful.
I haven't abused them in any way. I take very good care of my things, I appreciate having a nice pair of phones like these.
I appreciate any guidance and wisdom you could bring to the table.
Matt
Matt
