proid
- Mar 21, 2011
I'm building a 2 channel PPAv2 in bareboard with something changed from original:
- Dual +-12 rail regulated power supply, no voltage divider
- Change PN4392 to 2n5486
- 2n5087/2n5088 change to BC327/BC337
- No third channel
- both opamp and output transitor are powered by +-12vol
I have just finished wiring 1 channel and measure the voltage drop between output resistor (2.35R) : 5ma then i measure voltage between output and ground: 4.3V!! then i turn the trimpot to get 22mV drop between output resistor and the DC voltage at output is too high: 3.4V. Can someone give me suggestions? Thanks
- No third channel
