Rockin_Zombie
I got a First Watt J2 power amp and using banana-to-XLR cable to listen to my HE6 headphones through it.
I would like to also connect speakers to the amp. But I do not want to disconnect and reconnect the banana plugs every time I want to switch. However, I will turn the speakers off when listening to headphones, and disconnect the headhpone XLR when the speakers are on, so both will not be on at the same time.
What is the best way of going about this? Is there such a thing called banana Y adapters? Or can I connect both spades and banana plugs to the 5-way binding posts? I don't want to get a switch box because that's another additional box and might degrade the sound quality as far as I have heard, debatable though.
Thanks!
Thanks!
