zjred
- Oct 9, 2012
Guys, need some help on the above. I've recently switched to Android and experiencing issues connecting the ODAC to it. The devices are connected in the following fashion:
Xperia XZ-->OTG-->USB A to mini B cable-->ODAC-->O2-->headphones.
Upon connection, it sometimes give an 'error initializing USB system' message, otherwise when i click on the 'detect usb' function, it says success. The next thing i would hear is a series of beeps and that's it. Audio playback from the phone's speakers will be cut off and it looks like everything is fine except there's no music playing from my headphones.
Not sure if it is worth mentioning, the OTG is a Type C to Type A female from Belkin. I've also tried downloading the USB Audio Player Pro and nothing works. Any kind advice would be much appreciated. Thank you.
Edit: Android version is 6.0.1.
