After a month of research I finally purchased Sennheiser HD600, now the problem as you may guess is to choose a good amp/dac for them, I'm going to connect them to PC only, some people said a internal sound card is much better since it is directly in contact with the mother board, others have said external dac/amp is much better for HD600s, so as for the sound cards I found these two models : Asus Essence Xonar STX, Creative Sound Blaster ZX, and for the external I found : Chord Mojo (DAC/AMP), Beyerdynamic (AMP), Schiit Modi 2 + Schiit Magni 2.
Now my questions are:
1. Which one of the sound cards are better? Asus or Creative. (I kind of have this feeling the Asus but still)
2. Does Chord Mojo generates enough power to drive HD600s? (From the reviews it seems like it can but just to be sure) And can I have it plugged to the PC all time since it runs with the battery, I don't want it to leave me high and dry when I need it.
3. Does Beyerdynamic A20 needs a preamp device? (its an awsome amp as far I have read about it) if yes then what do you suggest? (Brand/Model)
4. does Modi 2 + Magni 2, generate good sound quality for HD600?
Thank You, Arin.
Thank You, Arin.
