FinnishSpartan
- Nov 27, 2011
Hi,
This will be a long post, if you find it too long to read, you can skip to the bottom for my setup configurations, please select one and explain why it would work the best. If you have additional suggestions, please be free to tell them as well.
I rarely post on these forums since I can find mostly anything I need to look for by reading the hundreds of already existing threads. However I would need expertise on more specific questions relating to my troubles.
I'm planning on purchasing the Sennheiser HDVD 800 (or the HDVA 600) soundcard for my HD800 headphones.
My current setup is as follows:
Asus Xonar Essence STX -> RCA output (w. Supra Cables) -> Lehmann Rhinelander amp -> HD800's
Now my problem is that I would like to know what is the best solution to get the most out of my forthcoming purchase of the HDVD 800 or the HDVA 600 (would need your suggestions on picking one of them depending on my output).
My original plan was to use the HDVA 600 with RCA inputs (similiar to my current setup), however I learned that the HDVD 800 would offer an intergrated DAC with USB or Optical/digital inputs. I've noticed that the Xonar Essnce STX gives a considerable boost in sound quality compared to plugging my headphone amp directly into my motherboards outputs. I've also learned that the Xonar Essence STX works similiarly to an external DAC. I've never tested any external DAC's in my setup though.
The digital output port on my soundcard is reserved for my 4.1 speaker setup (since it's the only way to provide true surround sound from this card). This leaves me the option of using the RCA plugs, using a 6.3mm to RCA adapter to connect to the headphone amp (for 3D gaming sounds), or getting a digital coaxial splitter cable.
My main question hereby is, would it make a great difference if I plugged my headphones into the HDVD 800 using a coaxial cable (and using the HDVD 800's build in DAC) to signal the sound to my HD800's (I'm planning on getting a balanced cable for the headphones) compared to using the RCA output (either trough the 2xRCA slots or the 6.3mm to 2xRCA converter) from the Xonar Essence STX with the HDVA 600's.
How about direct USB input on the HDVD 800's? This would mean that the Xonar Essnce STX would be completely out of the picture. Would it be better to plug the HDVD 800 through the soundcard rather then using the USB cable?
Here are the setups that I have in mind:
1. Asus Xonar Essence STX -> RCA output -> HDVA 600.
2. Asus Xonar Essence STX -> 6.3mm to RCA adapter -> HDVA 600.
3. Asus Xonar Essence STX -> Digital (Coaxial) output (with splitter) -> HDVD 800 (w. onboard DAC).
4. Motherboard USB socket -> HDVD 800 (w. onboard DAC).
5. Suggest your own setup.
All the setups would be connected to Sennheiser HD800's via the balanced outputs. Other headphones that I own would be connected via the 6.3mm output jack.
Thank you very much for reading through this post, and thank you even more for any suggestions on how I could achieve the most perfect sound. The new amp will pretty much suck up all my savings and thus I don't really have extra money to spend on testing different setups.
Also a bit late, but happy new year! =)
- Finnish Spartan
- Finnish Spartan
