faultfracture
- Apr 13, 2016
I have a lot of difficulty finding in ears that work for me. It's a little difficult even deciding where to begin considering my anatomy
My right ear canal is significantly larger than my left but I also suspect my left to have a larger than normal bend. I have a very difficult time getting tips that are small enough and I'm very sensitive to insertion depth. Very deep at all and I feel pain in my ears and using deep insertion earphones also resorts in a ton of wax in the earphones/tips unfortunately. Guess I'm not sure what I'm doing wrong...
I can usually get a good acoustic seal with earphones but the problem is keeping them in. Even if im not moving they also seem to work themselves out of my ears. I also have a very difficult time with my jaw movements drastically changing the sound of earphones. With a lot of them if I clench my jaw it's almost as if I can completely close the opening of the earphones and completely muffle their sound, this really bothers me.
Is there anyone that can recommend certain tips for someone like me to try? Even shure earphones design to sit in your concha bowls won't go into the concha of my ears without having to push so hard it causes pain. Any ideas?
