Need Beautiful Sound. Need Help.
Oct 26, 2008 at 6:22 PM Post #16 of 40
Logistics
Guys, I want to finally break down and buy a portable music player. All I care about is the sound quality. I was thinking an iPod Nano + amp, but I'm definitely open to other suggestions because I don't want to be stuck with iTunes; I want drag-and-drop. Is the iPod the only player with a line-out?
Something along the lines of 4GB would be good enough. That would allow me to hold around 8 albums if they were all in WAV format, and that will only be necessary for the ones I do critical listening on.
Edit: I hope to have the ability to output it to an after-market stereo head-unit for my vehicle as well.
Oct 26, 2008 at 11:27 PM Post #17 of 40
i_don't_know
Sansa Clip. Available in 1, 2, 4, and soon 8gb versions. FLAC support. Best sound quality you'll find in an mp3 player.
Oct 26, 2008 at 11:34 PM Post #18 of 40
tds101
Formerly known as nywytboy68
Or, for a larger capacity w/the same great SQ: a Sansa Fuze! Larger capacity as in microSD card slot. And, you can find it on Amazon for $93.93: Amazon.com: SanDisk Sansa Fuze 8 GB MP3 Player (Silver): Electronics
Oct 27, 2008 at 12:08 AM Post #19 of 40
i_don't_know
But it's chunkier. I think there should be a Clip V2 with a micro SD slot. That thing would just completely destroy all the competition.
Oct 27, 2008 at 2:44 AM Post #21 of 40
my.self
if u get an SD card for mp3 players, i think if not all, most of them become kind of like split memory. im not sure how to explain it that well so here's an example
if u buy a 8 gig mp3 player with an 8 gig SD card, when u turn on ur mp3, u can either access ur 8 gig that was built in or ur 8 gig SD card. i dont think u can merge the two together into one 16 gig device. im like..80-90% sure this is the case for all mp3's that support SD memory. keep that in mind cuz i know for sure that i personally wouldnt like something like that. i like the idea, but not the reality of it.
Oct 27, 2008 at 7:50 AM Post #23 of 40
tds101
Same w/the Fuze, full library integration. But,.......... it's "chunkier"? Oh brother!!!! Never mind, I'm out(LOL)!!!
Oct 28, 2008 at 3:30 AM Post #24 of 40
Logistics
This looks like what I'll end up getting. Drag-and-drop, microSD, 4GB+, and didn't someone mention that there's a possibility of Line-Out with software updates? Because, again I was really hoping to do external headphone amplification as well as be able to use it with an after-market car stereo.
Oct 28, 2008 at 5:17 AM Post #25 of 40
Logistics
Hmm... now I'm questioning whether I should get the Fuze 4GB for $68 or the Cowon D2 4GB for around $100'ish. The Cowon D2 sure is a beautiful piece of hardware compared to the Fuze.
What say you?
Edit: Do you have to use their software to drag-and-drop or can you just use Windows as normal?
Oct 28, 2008 at 6:35 AM Post #27 of 40
tds101
The D2 does sound better(I have both also, plus the clip), and it's drag & drop. Works with any OS actually.
Oct 28, 2008 at 1:33 PM Post #28 of 40
pangpang
my friends , i d like to give you some suggestions .
i am a chinese ,and i also a IAUDIO COWON D2 fan.
D2 is a good players with BBE .
I think you should choose Kenwood HD mp3 players which we talked
about more in China and Japan.
Cowon is not the best of the world.
Sony is a good choice,but not its mp3 players.
Sony pcm-D50 is a recorder ,but with a great SQ.
IF you have chances ,better to listen audio by your self .
Every one'S opinion on SQ is different .
Oct 28, 2008 at 2:44 PM Post #29 of 40
boozcool
Hands down, beyond a shadow of a doubt, the BEST sound quality in MP3 players is from the most recent Sony Walkman series.
I had a chance to sample all of the major MP3 players (Cowon, Apple, Sandisk, etc.) side by side, and the Sonys blew all of them out of the water. I even tried using the XM4 portable amp with the Sony Walkman in hopes of achieving even better sound, and the differences were barely noticeable.
I own the NWZ-A829, which is 16gb and has stereo bluetooth 2.0. For normal listening, I use the Audio Technica ATH-CK7 in-ear headphones. And with my Dell BH200 Bluetooth 2.0 headphones, I get great wireless sound quality for working out at the gym. Until lossless bluetooth comes out (hopefully soon?), I believe this is the best wireless option.
Oct 28, 2008 at 2:58 PM Post #30 of 40
Caribou679
Too bad it does not play Ogg or FLAC or Apple Loosless!!
regards,
